lost preprogrammed data in v folder 01
maxg
canada
Can preprogrammed data be restored from the psr- 500 disk and how?
Max
fmon
Silent Key Jan. 14, 2012
Eclipse, Virginia
Welcome to forum.
Max
Not with the control program on disk, but it can be restored with Win500 or PSREdit and in near future ARC500.
Edit: Don't be afraid to 'Load' a folder into "Working" because it still remains in the V-Folder spot until you 'Stor' a current "Working" or with a file using one of the softwares mentioned above.
Edit again: Should have mentioned you can also intentionally remove a V-Folder using F3 'Eras' key in V-Scanner operations.
DonS
Franktown, CO
fmon said:
Welcome to forum.
Actually, the program on the CD will let you upload the original VS "BIN" file to working memory. You could then use the scanner's keypad (FUNC + PGM, etc.) to move working memory to the target VS Folder.
EDIT: I suppose you could also use the CD's program to perform the "keypad" operations!
fmon
Eclipse, Virginia
DonS said:
Actually, the program on the CD will let you upload the original VS "BIN" file to working memory. You could then use the scanner's keypad (FUNC + PGM, etc.) to move working memory to the target VS Folder.!
Thanks, had to get the disk out to see how...it surly works.
