Low Power
police340
Hello,
I have a new 996T and see a low pwer message on screen. Did not notice it referenced in the manual. Can anyone tell me what this means. Unit is plugged into wall outlet now.
Thanks,
Bill
Raven95150
Nowthen, MN
I'd guess it means there is not enough voltage input to the scanner.
Sounds like maybe the wall wart is defective. I'd check the voltage at the plug (the end that connects to the scanner) with a multimeter.
Viper43
Hmmm, could be a couple things, first I'd try is another outlet, if thats the problem I'd suggest getting an electrician to check the outlet as it could have issues, and be a safety issue for you! If other outlets act the same and you have a multi-meter check to see the walwart is putting out the correct voltage , I forget but it should be between 12v and 13.8v DC.
V
