Lower Hudson River marine radio feed
k2hz
Rochester, NY
The feed is a great idea, thanks for making it available.
I just tried to listen and the audio is somewhat weak with a constant AC hum almost as loud as the audio. It sounds like you have an audio connection problem between your scanner and the computer. Possibly a ground loop problem.
I have to turn my volume way up to hear the audio and then the hum is very objectionable.
RadioChief55
I adjusted the volume and moved the radio away from another radio. It sounds much better on the laptop.. Give it a try and let me know how it sounds on your PC.
k2hz
Rochester, NY
The hum seems to be worse than before and no change in the volume. The volume indicator bars on the player are barely deflecting on voice and the hum is about the same level as the voice.
I have to turn the volume level up twice as high as any other RR feed and then the hum is unbearable.
I do not hear hum on any other RR feeds I checked even with my volume all the way up.
