LPE200 programming question
drunyon
Silent Key
Midwest
I am curious if I can program my LPE200 to scan one system and some conventional (both analog and Provoice) freqs.
I've been told by one person that it's an either/or sort of thing, but it can scan both a trunked system and conventional freqs at the same time.
Anyone here have any suggestions?
Thanks in advance.
exkalibur
York, Ontario
You can scan both trunked and conventional together in an LPE200.
What you cannot do however is have both conventional and trunked channels in the same system.
You need to enable the "scan across systems" flag and you should be good to go.
drunyon
Silent Key
Midwest
Okay...I thought I knew what I was doing, but apparently not.
I am trying to program an LPE200 (system) with ProGrammer (TQS3385) (version R16A05). I have one Edacs trunked system in system 1 and about 10 conventional frews in system 2.
I want to be able to put the radio in scan mode and have it scan both the trunked system and the conventional freqs at the same time.
Can anyone provide any tips to make this happen?
Thanks again.
