You might be able to
This is a rough idea or concept of the process that need to be completed for an ltr system.
A mobile duplexer will cost you 280.00 and up or you can get a uhf repeater with it in it for 1800.00 bucks about at 33 watts out on uhf, firgure another 2,000.00 to 5000.00 for a ltr logic unit interfaced, not sure exactily what the firgures are off the top of my head right now. Coxical cable run for 60 ft firgure somewhere between $0.69 up to $5.00 per foot for decident cable with a 5ft or 10ft whatever is more practical jumper cable for the lighting arrestor and repeater to be feed off of at 100.00 or so dollars. Grounding kit, 100.00 or more.
Then licensing costs for a yg / yk license if uhf / vhf trunking system. Check on-line with PCIA for actual licensing costs for uhf as opposed to vhf. More then likey you'll want uhf radios if at all possible. They usually play nice in most environments. 60ft at 33 watts with siginal degoration, proabily realstically tpo of 30 watts and you can get decident gain antenna form 100.00 up to 1500.00 dollars, 15 to 25 miles depending on area, etc. Equipment tools and die's etc give off rf which can reduce you ability as well.
Now, radios
30 units, Icom IC-F4061T which support basic LTR 272.15 =$8,164.00 thats whats on sale. I'm sure with quantity you get that price cheaper as well. As most give discount for 10, 25 or more radios. ^ bay gang chargers run 250.00 up to 400.00 a piece.
400.00 X 7 cradle to charge spare batteries which you will need. $2800.00, then spare battery cost (high end) 100.00 X 12 spare batteries= 1200.00. Ideally you should half of the total amount of radios you have in spare batteries.
Kenwood portables are going to run you alot more then that. When you break down 17,000 oes not seem all that bad for all the work behind the infrastructure. Oh, yea I forgot the cost of labor to climb the tower. Theirs lots of ways around this if you have the right circles. The portables seem rather high, but are you get any accessiories an addition to the radios.
Oh yea, and it might be a wise idea to get the software and programming cable as well at this point. Thats about $200.00 or less just to have if you need to make sight modifications on talkgroup assignments or created new ones.
