I tried putting LTR systems off of Sentinel, and when I activate on the scanner I get the message "Scan Mode. Nothing to Scan".
Any ideas?
Any ideas?
Any ideas?
Go through the "Nothing to Scan" checklist, looking for items that might not be entered, or were entered incorrectly.I tried putting LTR systems off of Sentinel, and when I activate on the scanner I get the message "Scan Mode. Nothing to Scan".
Any ideas?
That would not generate a "nothing to scan" warning. However, just about all of the LTR systems (in the database), that I've looked at in the DFW Metro area are no longer active. The system may no longer be in service, or at least not as LTR. The majority of the LTR systems that might be of interest to me have migrated to using DMR, instead of LTR. Unless someone has discovered the changes, and submitted the corrected details to the database, the system may be, incorrectly, still tagged as LTR. If they are now DMR, you would need the DMR upgrade for your 536HP to be able to monitor them.First, depending on where you are, the LTR systems may no longer be active at all.
Please attach your favorites list so we can take a look at it to check for errors. Go to the File tab in Sentinel and click on Export to hpe file (Favorites List). You will need to zip the exported file to be able to attach it. Click on Attach files and open the zipped file.I tried putting LTR systems off of Sentinel, and when I activate on the scanner I get the message "Scan Mode. Nothing to Scan".
Any ideas?
