M f j 971 wurry
radioshane
york
Dear forum members I got a m f j 971 on Saturday and I’m just enquiring how the set can tune a Alinco R 8 e high frequency communications Reciever
merlin
DN32su
It is a basic tuner, but does have a single wire input. It will tune about any HWLW you have up.
It will couple to any receiver with 50 ohm impedance.
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
If you are talking about this...
A simple coax connection will do the job. Really though, you probably don't need this if you are working with a good sized wire antenna. These kinds of units can sometimes help with a short or less than optimal antenna. Exactly what will you be using as an antenna?
Mike
  • Like
Reactions: wtp
radioshane
york
Dear administrator Mike
My aerial is a long wire high frequency aerial it’s allready up .
Could you advise what I do with the inductance knob please 🙏
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
I'm not an admin...
find the best combination of inductance and capacitance that produces the quietest (not necessarily loudest) signal. It's not rocket science (hi)
How long is the antenna?
Mike
merlin
DN32su
Start with inductance switch set for best signal to noise then back and forth a couple time for both capacitance.
The goal is best signal to noise. the losses may not be the strongest signal but can improve DX quite a bit.
radioshane
york
A long wire aerial with a small half wave dipole inbetween the coaxial cable and the long wire
