MA/COM P7100IP model chart info
jim202
New Orleans region
Trying to figure out what this P7100IP radio is for band and has in it. The model number is HT7170T81X.
There is also a sticker with the number RU101219V72 R1B
This is a system model with a full keypad.
I think it is an EDACS portable on 800, but not totally sure.
Jim
wa8pyr
Staff member
Lead Database Admin
Ohio
Yes, 800 MHz.
To tell what features are in it, go to the menu, scroll to Features, hit Menu again, and use the up arrow key to scroll through. You'll eventually (probably after the CNVCHN# screen) see a series of two-digit codes similar to "01 04 05 06 07 08 09 10 12 21 22 23 33 39." Those are the feature codes; you'll need to use a list to figure those out:
The one I quoted is:
01 - Conventional Priority Scan
04 - EDACS Group Scan
05 - EDACS Priority System Scan
06 - EDACS/P25 ProScan (ProSound / Wide Area Scan)
07 - EDACS/P25 Dynamic Regroup
08 - EDACS/P25 Emergency
09 - Type 99 Encode and Decode
10 - Conventional Emergency
12 - Digital Voice
21 - EDACS Security Key (ESK) / Personality Lock
22 - ProFile
23 - Narrow Band
33 - P25 Common Air Interface (CAI) – P25 Conventional
39 - P25 Trunking
Forts
Ontario, Canada
You may also find the Features option isn't in the menu... That can be removed when the radio is programmed.
