Madbury Pd
mainetrunk
York county Me.
It looks like Madbury has joined the --mix-- transmission group. I just happened to be doing a quicksearch last night and caught 155.775--136.5... I monitored for a few, and realized it was 1 transmission, so I cleared the pl and there it was, a mix communication. P25 on 1 end, analog on the other.. Dover does that--not wild about it..
QDP2012
How would that work? Is it a type of hybrid configuration within one system? Or, is it simply a patch between a newer P25 TRS and an older analog frequency?
Just curious,
mainetrunk
York county Me.
THAT--I couldn't say. All I know is 1 minute they are p25, the next is 1 side of the transmission,now the other side is analog. Dover, Somersworth, now madbury plays with that. Except Somersworth uses it to talk to AMR and American ambulance--( ambulances are analog to dispatch, p25 return to ambulance--pd all p25 )
jmarcel66
Concord, NH
Just curious,
NH as a whole does not use any TRS. It is conventional P25 and/or analog. They simply program the channel(s) to be mixed mode receive and transmit either P25 or Analog.
Nashua & Manchester, NH use TRS, but are separate from the rest of the state.
ecps92
Taxachusetts
Dual-Mode allows units to use either P25 or Analog
Unit A - could be P25 talking to Unit B who is using Analog
Both Could use P25 or both Could use Analog as well, all depends on which mode/channel the radio is enabled on.
Sounds like you are confusing Trunked Systems and P25
P25 can be Conventional not just trunked
Just curious,
QDP2012
...Sounds like you are confusing Trunked Systems and P25...
Yeah, in that moment, I had assumed "TRS" when reading "P25". I should've known better, especially since I've listened to other dual-mode systems before. Thanks for the reminder.
