RedPenguin
- Joined
- Feb 28, 2007
- Messages
- 1,082
If you are trying to make a "random wire" antenna for the Sony ICF-7600GR and are using a mono plug meaning just the tip and barrel, not having 3 correctors like headphones, should you keep both wires separated or connect both the tip and barrel connections?
I can't seem to find the specifications for the external antenna jack.
I noticed that one connector always seems to be dead. I mean, one connector, it acts as an antenna, if you put it on the other connector, it is just silence, no antenna action going on.
Also, why is this? I noticed when I hook up the ends together, it works wonderful on FM, but 850 WNTJ which is our local news talk channel, is almost completely silent.
I thought at first, the antenna was only for AM, but I notice, I can only get in some FM stations by plugging in an external antenna of some kind.
