Malahit vs Malachite DSP w/2.4
bearcatrp
Land of 10,000 taxes
Don't have an answer for you but when you do get it up and running, would appreciate a review of your new radio. May want to get that radio for my HF listening.
VK3YMML
VicScan Forum Owner
Melbourne, Victoria
Unfortunately I flashed it with the wrong bin file and now it won't turn on. The light comes on the side if plugged into power or a pc
Attempting to locate how to repair
bearcatrp
Am on the IO groups and saw someone posted that the radio you bought is a fake chineese knock off. Not a official radio. Is that true? I like the design of that radio.
VK3YMML
VicScan Forum Owner
Melbourne, Victoria
I ended up removing the message, people can be so negative at times.
I've found a Facebook group that's been more helpful
VK3YMML
VicScan Forum Owner
Melbourne, Victoria
Unfortunately I brought the item 3rd hand, I have no contact with the original eBay or Aliexpress seller
Maybe I just have a radio paper weight
VK3YMML
VicScan Forum Owner
Melbourne, Victoria
Suggest you contact aliexpress. Could get lucky.
Unfortunately I don't know the original person/site it was purchased from.
Furthermore the DSP button on the board is either faulty or has other issues. I can get the unit into DSP mode and then it promptly disconnects.
bearcatrp
Maybe send a message to these folks to see if they can help.
VK3YMML
VicScan Forum Owner
Melbourne, Victoria
Can you get the original firmware for it?
Yes. I have the firmware. The problem is that any attempts to put the unit into DSP mode fails. The unit connects to the PC via USB and then within 2-4 secs disconnects.
Tried and tested on two different machines (Laptop and PC) and different cables. Both data cables used with a HackRF
VK3YMML
VicScan Forum Owner
Melbourne, Victoria
How did you get it back up?
Dismantled the radio, pushed the DFU button on the board then connected the battery (Fully charged) and then connected the USB cable then let go of DFU button
Was able to install the basic .hex from Malahite Website. After that had to send off $50 USD for new firmware with Key registration
