MARCS P25 Channel ID Table
daine1619
Washington, Pennsylvania
Does anyone with more experience listening to the MARCS system know the P25 Channel ID Table?
I was attempting to listen to it and was having some issues that seemed to be around the Channel ID Table.
I used the P25 Channel ID Table from the RFDB, and it says Channel IDs 1 and 2 should have spacing at 12.5 KHz. I thought this was off because all the other phase 1 systems I listen to use 6.25 KHz on the FDMA 7/800 Channel IDs. I am not an everyday listener to the MARCS system and wanted input from people who listen to it more before making any change submissions.
mtindor
FMP24 PRO USER
Carroll Co OH / EN90LN
Here is is from DSDPlus:
Network: BEE00.348 ; Ohio MARCS
Bandplan #0: Base=851.00625 Offset=-45 Spacing=6.25 BW=12.5
Bandplan #1: Base=762.00625 Offset=+30 Spacing=6.25 BW=12.5
Bandplan #2: Base=851.0125 Offset=-45 Spacing=12.5 BW=12.5 Slots=2
Bandplan #3: Base=762.00625 Offset=+30 Spacing=12.5 BW=12.5 Slots=2
So you are right, it is off. It needs to be corrected in the DB. I just updated the database.
Tcp14Gd
So, if the system is in the DB and you program your scanner via Sentinel, this information is simply contained within?
I've never programmed a P25 System "by hand" but if you do, there are places to enter all these parameters, yes?
redbeard
OH, PA, WV Regional Admin
BEE00.348-3.1
It's mostly only used by people trying to program commercial radios to monitor with.
