Is it possible to program a Motorola radio to convert to a Marine VHF???
It would be a Motorola cp200d but I am almost sure it requires some type of certification. My plan was to just program the main channels not all. But probably needs a certification. Is the FCC Type 80 certification only for transmitting.There is more than one Motorola radio. Which model?
If it's a VHF radio that covers 156-162 MHz, capable of wideband, and can hold about 100 channels then it's possible to program all the VHF marine channels but it wouldn't be legal to use as a marine radio unless it has FCC Part 80 certification.
Thank you so much for answering all my questions very much appreciated !Look on the radio's label and get the FCC ID.
Then look up the FCC ID number on FCC ID Search or https://fccid.io.
If the radio has Part 80 certification it will be listed on the equipment authorization grant.
I don't know off hand if marine radio equipment authorization only covers the transmitter.
If you intend to use the radio for anything but hobby monitoring you would probably be better off buying a marine radio.
Good to know.CP200d does not have Part 80 certification. Would not be legal to transmit with that radio. Totally OK to use it as a receiver only.
Oh that’s cool. I didn’t know you can call Motorola to get it FCC part 80 approved. Thank you so much for that information I really appreciateMany older Motorola models are FCC part 80 but if its for receive only it doesn't matter. I was involved in a remote marine shore radio job in the 80s for Sea Tow or similar where we used a Motorola Radius M216 then found out it was not FCC part 80. We contacted Motorola and within a short amount of time they got that model radio FCC type accepted for part 80 and we were good.
It was just good timing, the Motorola model was current at the time and our person that contacted them gave a sales pitch on the need for remote marine stations and if they could get it type accepted it might generate more sales. Whatever the reason Motorola pulled off a very quick job on getting it type accepted. I would be surprised if they would do that again.Oh that’s cool. I didn’t know you can call Motorola to get it FCC part 80 approved. Thank you so much for that information I really appreciate
Never used a CCR, but turning Duplex to "OFF" would mean simplex, not TX inhibitI programmed a Baofeng UV6R for receive only - Turn "duplex" to off with chirp.........No desire to xmit, only listen.....
Waiting on a uv5"m" to come out
thanksI beg to differ.......I can not transmit on any frequency (channel) I turn duplex off with.
However it is possible in "VFO" mode
No I have not tried it, as my Original post said "Never Used a CCR" aka Don't own any.Then try keying up after doing it - Since I have no need to transmit on certain frequencies this
approach works for me. (have you tried it?) "Off" is the bottom choice in the dialog box in "duplex."
