MARS Mods
N9JIG
Sheriff
Moderator
Far NW Valley
I have performed the MARS Mod to some of my radios and still cannot for the life of me figure out what I did wrong. I have been working on this for a month and it has been driving me batty, well more so than normal.
On my Icom IC-7300 I removed both D422 and D416 as directed but no joy.
On my Icom IC-705 I removed the two diodes on the board (after quite a bit of disassembly!) and still no joy.
I also removed several other diodes on the 7300 and 705 to see if perhaps the websites listed the wrong ones but got a few weird display artifacts on both radios and on the 7300 some odd burning smell coming from the radio when I transmit. Eventually the 7300 stopped working altogether, it will no longer power on, the 705 seems to receive and transmit but with the weird screen display.
So I went out and bought another 7300 and another 705 to see if perhaps I hit the bad board lottery and got 2 defective radios. I needed to replace the 7300 anyway as my original does not work any longer and Icom won’t repair it. I did the same modifications to the new radios and now the new 705 won’t even turn on, the new 7300 works as before the mod but the MARS mod doesn’t seem to work.
So next I tried firmware versions. Of the 2 remaining (semi) functional radios I was able to update the firmware on the 705 but not the 7300. Still no joy however.
I am now starting to suspect that perhaps it is my antenna system. I have several different antennas available, but none seem to do the trick.
Can anyone please explain exactly how I am supposed to be able to contact Mars? It appears the mods do not seem to work as advertised? The only response I have been able to get is April Fools, and that came from some guy on Venus.
K4EET
Chaplain
Severn, Maryland, USA
When you did the “MARS Modification,” since the components are microscopic 😂 and the boards are not friends with static electricity 🤣, did you have the proper setup to do the surgery? Of course anything is possible — bad instructions, blown components, damage to multilayer circuit traces, etc.
By the way, while you are buying ICOM IC-705s, wanna get me one too? 😳 I promise I will not attempt any modifications… 🤣😂🤣 TIA!!!
merlin
DN32su
Consider your source of information. Look up your radios in Art Sci's radio mod books. What is published has been tested and working.
Should be able to get Jupiter then.
K4EET
Chaplain
I see where HRO wants $120 after coupons and promotions for the MARS Modification on an ICOM IC-705. Must be a real pain to do the surgery to get to the components that need to be modified or there is more to the mod than is being revealed.
Also, some instructions mention a “Japanese version” which may be different than a stateside version. Are you sure that the instructions match the model?
KevinC
32D2T/957.282
Super Moderator
I'm everywhere Focker!
Is your squelch set to 2?
UAT_978
I was able to open my IC-905 to do CB but it only does LSB and VSB. I will try sending NTSC TV over it later. Does anyone have the mod to get it to do 36GHz?
It also opend up the 40 MHz CB band, but I am not sure if the channel numbers are correct.
merlin
DN32su
40 MHz or 40 channel ?
My TS-440s was one diode for full HF TX and another for 10Hz resolution on the display. CB channels I added to channel mode.
You go chopping out diodes you now have a development plaform. (parts radio)
You must be down under, UHF CB.
