Marshall Co. Sheriff (IL)
llwade
Chillicothe, IL
I have listened to Marshall Co. Sheriff, for quite some time. the other day, I reprogrammed my scanners, using Marshall Co. Public Service (DMR).
I have NOT heard them once and was wondering what others are hearing. I even went to the extent of programming each site separately.
Thank you for your time.
Mex
///marathons.antenna.interviewer
Is it a possible there are no calls in progress? Alot of these rural communities can go hours without any calls.
Its also possible they changed color codes or possibly switched back to a fallback channel because of a issue with the digital system
Starcom21
IL /MO/Global DB Adm!n
Do you have them programmed as one freq system? Listening in talkgroup search mode?
Listen to the closest site in tune mode, hear any data? Plug the channels in analog and see if you pick up digital noise at all
llwade
Chillicothe, IL
sorry, but that just went over my head.
I use ARCX36PRO program to upload everything into the scanner
can you explain what you are saying in simplier terms
thank you for your time
llwade
Chillicothe, IL
Is anyone hearing anything on: Marshall Co. Public Safety IL DMR conventional ?
IDTG 620-Sheriff, 629-Fire/EMSA?
