marvinsuggs PL decode
W1KNE
No Filter Zone
New England
Hey @marvinsuggs , moving here for a moment for you. Are you searching or using pre programmed frequencies? If you are searching, on the scanner, make sure the search option (on the scanner) is set to CTCSS/DCS decode. (Menu->Srch/CloCall Opt->Tone Code Search-> Select CTCSS/DCS search)
ecps92
Taxachusetts
Thanks for writing! I figured it out finally. You have to select ctcss search on each channel. Works great now!
That would be correct, if Pre-programming for each frequency.
That is a lot to pre-program vs using a predefined search band of say 29-50 or even chunk it down to 29-33, 33-43 etc
When in the Search, you should then be able to select (forget the wording on that radio) to auto detect the PL/DPL for logging
W1KNE should be able to help you more
