Maryland DNR
garyjsss
md
I have been monitoring DNR for a month now and have not herd a single transmission. I downloaded all freq.
what am I missing.
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
I can't resist - an antenna? a scanner? <chuckle>
Did you download the data in our database? I hear 159.09 and another channel in my 396 quite frequently. I even hear it with a small active antenna on an old klunky BC895. I have found they aren't quite as active in the winter - but very much so in the late spring, summer and fall
There's a lot of old info out there. The database is much better. I understand that most all of the DNR vhf-lo band stuff has been abandoned, so you might want to concentrate on the hi band stuff instead. I've submitted a change log to the database to get that done.
See these threads
http://www.radioreference.com/forums/showthread.php?t=130307
http://www.radioreference.com/forums/showthread.php?t=111896
73 Mike
garyjsss
md
dnr
Hay Mike, after i left to go back to work i realized i did not leave very much info. sorry about that.Here's the low down. I have a 396t, most of the time i am in ocean city area, all the ch in rr were down loaded to the radio. along with oc,worcester co,and local del. All are working fine except dnr. thanks gary
hill
Middle River, MD
They operate on 151.205 Mhz with a tone of 103.5 Hz. Should be able to receive them very well, since use a tower in the OC area. The units in this area use 100 series callsigns. Some of these units also carry Worcester Co. TRS radios and operate on the Sheriff's Department talkgroups. Every time visiting OC I see MNRP trucks driving around the inlet area looking at people fishing on the jetties, so should have traffic on the radio system. I get down to this area in both the warm and colder months of the year to visit my brother and always hear radio traffic on the above freq. Hope that helps you.
Larry
garyjsss
md
Thanks Larry, u said they operate on 151.205 with a tone of 103.5. Is that tone something i need to program in the radio before it will receive a signal.
hill
Middle River, MD
No you don't need to program the tone, but just help cut down on interference and intermod signals. You can just program 151.205 Mhz into the scanner and it will just fine.
Larry
