MassPort Interops Channels
zerg901
yup
Channel Configuration Channel Name/Trunked System Talkgroup Eligible Users Mobile RX Freq N or W RX Tone / NAC Mobile TX Freq N or W TX Tone / NAC Mode A, D, or M Notes
Trunked MPA COMMAND State 700/800 MHz Trunked Radio System M Command/Control/Coordination
Trunked MPA EMERGENCY 1 State 700/800 MHz Trunked Radio System M As Assigned
Trunked MPA EMERGENCY 2 State 700/800 MHz Trunked Radio System M As Assigned
Trunked MPA EMERGENCY 3 State 700/800 MHz Trunked Radio System M As Assigned
Trunked MPA EVENT 1 State 700/800 MHz Trunked Radio System M As Assigned
Trunked MPA EVENT 2 State 700/800 MHz Trunked Radio System M As Assigned
Trunked MAP EVENT 3 State 700/800 MHz Trunked Radio System M As Assigned
Trunked MPA TRAINING/EXERCISE State 700/800 MHz Trunked Radio System M Training/Exercise Coordination
Trunked MPA WIDE (AN) State 700/800 MHz Trunked Radio System M Wide Area Coverage within Rt.495
Trunked MPA WIDE (DG) State 700/800 MHz Trunked Radio System M Wide Area Coverage – All Digital
Duplex MPA-FD1 (BOS) 453.9000 N D205 458.9000 N Dxxx A Fire-Rescue – Console Patched
Duplex MPA-FD5 (BED) 460.6375 N D365 465.6375 N Dxxx A Fire-Rescue – Console Patched
Duplex LOGAN REPEATER (AN) 854.9625 W D365 / $365 809.9625 W $xxx M Backup Repeater – Analog Mode
Simplex LOGAN DIRECT (AN) 854.9625 W D365 / $365 854.9625 W $??? M Direct – Analog Mode
Duplex LOGAN REPEATER (DG) 854.9625 W $365 / D365 809.9625 W $xxx M Backup Repeater – Digital Mode
Simplex LOGAN DIRECT (DG) 854.9625 W $365 / D365 854.9625 W $365 M Direct – Digital Mode
from https://www.mass.gov/doc/massachusetts-interoperability-field-operations-guide-mifog/download
