mast options
KB3KBR
(ಠ_ಠ) (◣_◢) (。◕‿◕。)
Oil City, Venango County, PA
Hi all, just wondering where you guys procure your masts for your antennas from. My last mast came from radio shack back in the early 2000's.
prcguy
I use a lot of chain link fence top rail which can be had in 21ft lengths or 10ft lengths of EMT conduit. Here is a project to make a 20ft pushup mast from Home Depot parts and a clamp off eBay.
AK9R
Staff member
Super Moderator
Central Indiana
Spiderbeam in Germany has several varieties of friction-lock telescoping fiberglass masts.
DX Engineering, GigaParts, and Chameleon have different varieties of friction-lock telescoping carbon fiber masts.
DX Engineering and Max-Gain Systems have cam-lock telescoping fiberglass masts.
Several outlets sell the old-fashioned, and heavy, Rohn steel telescoping mast.
mtindor
FMP24 PRO USER
Carroll Co OH / EN90LN
I've been using the Max-gain Systems cam-lock telescoping masts for well over a decade. Not cheap. And the ones I bought I had to glue the cams onto, which you do have to be careful with if you want the fiberglass tubes to extend/retract properly afterwards. But they are great for wires or verticals or 450/700/800 yagis, depending upon how far you want to raise them up and whether or not you actually use any guy rope/wire. At one location I had one of their 48 footers extended all the way, with a Alpha Delta 160m trapped dipole. I never used any guy rope, depending solely upon the inverted V wire at 48 ft to act as the sole guy. Granted, that only handled guying in two directions, but with the lightness of the load I had on it I never had problems. At another location I used to extend them up to 35' without any guying with a Diamond X500 (or was that 300) and a 700/800 yagi on it. Worked fine, and I could easily bring it all down. Of course, it's easier with 6-foot fiberglass lengths than 8-foot fiberglass lengths since one can then reach the bottom cam easily from the ground.
Not for everyone, or every scenario, but they have always worked great for me.
Mike
10' rigid electrical conduit from Home Depot for a remote site install with a single UHF folded dipole on it.
For anything at a real tower site, I go with the specific mast products sold at places like Tessco.
KF0NYL
I am using 1 5/8" fence posts with some 1 5/8" couplers I found on Amazon. My mast is 24 feet long and I have the mast clamped to the house in three spots. I also have it guyed with some Mastrant 1/8" guy rope at the top. My Comet GP-9 and a 10m inverted v dipole are currently on the mast.
It has held up fine through the typical midwest spring storms. I lost a maple tree last year on Easter and the mast held up fine.
I have a DX Engineering 25' telescoping mast that I use for portable setups.
