Apologies in advance--already did a search for this here but didn't come up with a definitive answer.
In any case, I understand the 7-8 hour battery life I've been getting with the PSR-500 is going to be a lot less than that 20-30 hours I use to get with my Pro-95. Then again, this life figure was based on battery abuse--having the backlight turn on with certain frequencies and doing many uploads and downloads with scanning software. Now that the pinball machine phase of this is over, and I'm pretty settled with my frequencies and settings, I want to see what I can do to squeeze a little more battery life out of this.
I've already turned off all backlight operations. Just wanted to know whether there are other things I should be doing. For example, should I deactivate the LEDs? I would think that they don't draw nearly as much current as the backlight, so I'd prefer not to lose them. I've switched over to rechargeables, so battery economy isn't such an issue anymore.
Any other suggestions?
Suzie
Suzie
