Maxtrac?
yorkphotog
Toronto, ON, Canada
I'm looking for a Maxtrac on eBay...it has to do 800 Mhz SmartZone trunking. A lot of the eBay listings do not make mention of whether they will do SmartZone trunking or not. Are there any particular model numbers that I should be looking for?
Thanks!
C138NC
Tactical Taco Consumer
NC Taco Command
Found a thread in the archives that a user was selling his maxtrac and it was 800mhz, he did mention it had privacy plus trunking, didnt know if thats the same thing you are wanting for a smartzone trunk set up.
Below are just the model numbers i saw on it, hope that helps you find what your looking for. Most ebay listings are never accurate or never been tested to insure what it does.
D35MW5GF_K
438TUU0343
http://forums.radioreference.com/old-classifieds-archives/156019-motorola-maxtrac-800mhz.html
its probably no longer available but you could could probably get the best help from him.
n2hbx
Lady Lake, FL
I don't think Maxtracs can do SmartZone. SmartNet, yes, but not SmartZone. If you really need SmartZone, you're going to need a Spectra.
Larry
rescue161
KE4FHH
Hubert, NC
Privacy Plus is not SmartZone. It's the old Type I trunking.
The best that you'll be able to get with a Maxtrac is SmartNet as previously mentioned by n2hbx.
ronenp
Prvacy plus is not good
but If the radio Has Logic board with 16 pin accessory connector you can replace the eprom and reprogram the radio and it will do smartnet and smartnet can work on SmartZone System with few limitations
