MCD 5000 Consolette programming
Romeo-Tango
Dear forum ,
could you help me go through step by step on how to program MCD 5000 Consolette Motorola and how read/write the code plug
what should i use as cable to program it?
thank you in advance,
Ahmed
jmfirefighter
Raymond, NH
This is not a trivial task, and not one that can be done "step by step" on a forum.
Step 1: Sign up for a Motorola Solutions Learning Portal Account: Motorola Solutions
Step 2: Search for MCD5000, a number of options will come up. The manual you want, however, is
MCD 5000 Deskset System Without OMC Installation and Configuration Guide #6802987C97-S
You'll need to find the MCD5000 Configuration Tool software to program these units. It uses a standard straight through Ethernet cable.
jmfirefighter
Raymond, NH
should i use APX Family R28.
No. You need a specific piece of software called "MCD5000 Configuration Tool". No other software will program a MCD5000. Please find and read the manual I posted about, all the information you need to properly program a MCD5000 is in there.
APX CPS is ONLY for APX consolette, portable and mobile radios. It will not program any other Motorola products.
n2hbx
Lady Lake, FL
You will also need to access the controller board inside the consolette and program it to recognize the MCD Deskset.
Larry
ffexpCP
wizard of odd
Michigan
Where did they move it to? I have a license for it, but can't find it. I thought it was on my old MOL account. I don't see it in myview / customer hub tab for entitlements?
n2hbx
Lady Lake, FL
Larry
I should have added that you access the controller via your web browser, not APX CPS.
jmfirefighter
Raymond, NH
And Techsonic, which I found interesting.
That's because the newer Technisonic (TDFM-9000/9200/9300/9100) aircraft radios are actually APX portables in a chassis. The programming cable is a USB APX portable cable with the Technisonic jack connected at the end. Somehow they convinced ($$$) Motorola to allow them access to the software/firmware of the portables to put the display and control functions into their user interface.
The older TDFM-600/6000/7000/7300 series are ASTRO25 XTS portable based units, and use ASTRO25 Portable CPS.
