Tytera MD 9600
eaf1956
Evansville, IN
Today My MD 9600 lost it's display. Turned the radio on to a solid white screen. I reloaded the firmware, can do upload and download of programming but the screen is solid white.
eaf1956
Evansville, IN
So how does everyone like the New CPS and Firmware for the 9600? I do like the 100,000 contacts CSV display. Not sure on the split channel thing.
K6KEN
Hemet, Ca
TYT-MD9600 Blank Screen Problem - White Screen of Death
Hi all,
This may have been asked before and answered, but here it goes. I have a version 1 MD-9600 that has suddenly decided to give me the white screen of death. The radio works and programs, but the screen stays completely blank. The buttons also appear to work but no joy on the screen. The screen worked before and suddenly stopped. I firmware upgraded to the latest version to see if that helped but no dice.
Any ideas anyone?
eaf1956
Evansville, IN
Hi all,
Any ideas anyone?
Same thing happened to me. I got lucky and got a replacement from the vendor.
Jimbo695
Hauppauge NY
Should I Get One ?
Hi, folks. Thinking of getting the TYT 9600 as a base unit. What's the consensus, please? Have all these many issues been addressed in the current units? Will I have to upgrade firmware and software myself once I get the unit (I can do it but shouldn't have to with a unit purchased new from an authorized distributor)? I like the idea of a dual band with DRM capability but I don't need all these headaches. Opinions appreciated. Thanks!
eaf1956
Evansville, IN
Want to buy mine? I actually prefer the CS 800D from Connect Systems over the MD 9600.
Jimbo695
Hauppauge NY
Appreciate the offer but I'd still like someone to weigh in on my questions. You sound like you're telling me that the CS 800D is the better radio. Anyone else, please? Thanks to all.
yeg_scan
CS800D is a great radio, also have a CS800 and both are wonderful.
Probably like the person above I would not even consider a 9600, even though I do like my MD380, but they have gone really downhill since that model.
vinsky
Canada
Hi. What is the latest HARDWARE version (May 2018) of the MD-9600 ?
Thanks to all!
SCR584
Dayton Oh
White screen
Hi all,
Any ideas anyone?
Mine failed this past winter every time the temperature went below 36 F it would turn white. Then one day after the temp dropped below 30 F it died. Sent it back in for repair to dealer they replaced it instead. Just got around to putting it back in my van so far it has not failed but then it hasn't been below 50 F either. Will see next winter what it does.
2e0saf
hi all i just bought a second hand md9600
where can i find up to date contacts for md9600 please...?
also how do i know if the radio i have is a upto date version etc..?
thanks
W8JJV
MD 9600 Popping Problem
Can someone point me to the mod to fix the popping problem. I know you need to add a resister and capacitor I just don't know the values of the components to add or where to put them. Is there detailed instructions somewhere
Phillipsc84
Fort Mill, SC
I believe this post from earlier in this thread will answer that...
The popping and audio taper can be fixed with hardware mods. It requires a .1 capacitor on the audio amp and a 1k resistor across the volume pot pins. I've done both and they work.
Here's a guide on what to do...
https://www.pc5e.nl/downloads/rt82/manuals/Mods%20for%20Tyt%20MD-9600%20By%20Colin%20Durbridge.pdf
But in the interest of keeping this mod updated I recently got an MD9600 with V6.03 firmware and the "NEW" hardware. I noticed something not seen in the images at the above link for the 1k resistor mod. There appears to already be a resistor here. But the volume seems to still get way too loud way too quick.
Any thoughts?
