medevac rids
QDP2012
I am guessing that you are trying to find "radio id's" used within trunked radio systems. RIDs and UIDs for trunked radio systems often are stored in the Wiki.
For New Jersery, if you haven't already, you might check the systems listed in RR Wiki: Category:New Jersey RID/UIDs to see if any of those Trunked systems are used by medevacs.
You might also check the listings in the RR Wiki: Category:Medical Aviation category in case some apply to NJ.
Hope this helps,
nosoup4u
High Bridge, NJ
If things ever slow down, I will add a 3rd column for service type so it will be easier to pull out classes of radios.
nosoup4u
High Bridge, NJ
This is a good time to point out where the the various files are:
The master list, along with 700/800 .txt files to make it easy to import into your scanner are here:
https://www.dropbox.com/sh/4rxgywkd7xe6fch/AAAxFoNA-CToO9WxjT2iLqJka?dl=0
The NJICS spreadsheet listed by county is here:
https://docs.google.com/spreadsheet/ccc?key=0AoqGhFVYBsnqdHdRX1RpS2ZiQWVNRG8xRHdmSVFvQ3c&usp=sharing
I just added the NJICS sheet to my dropbox, so you should be able to link my dropbox folder to yours and you will automatically get the updates.
