Sentinel: Memorial Hermann Lifeflight...
Houston, Texas
I am trying to find out information on Memorial Hermann Lifeflight, Houston, Texas.
I have tried looking here on the RR database and all I could come up with is information
listed here.
Says several Medevac services as well as Lifeflight operations are on the TxWARN network, but I am unable to locate
Memorial Hermann Lifeflight in the database.
KevinC
32D2T/957.282
I'm everywhere Focker!
Talkgroups​
DEC HEX Mode Alpha TagDescriptionTag
1300dDLifeFlt CtrlHermann Life Flight ControlEMS-Tac
34815cDPHI Med 12 BryanPHI Med 12 Dispatch (Bryan Base)EMS Dispatch
1106452DPHI ControlPHI ControlEMS Dispatch
1369559DLifeFlt DispHermann Life Flight DispatchEMS Dispatch
3649e41DHCA Air PrimaryHCA Air PrimaryEMS Dispatch
3650e42DHCA Air AltHCA Air AlternateEMS-Tac
Enforcer52
Voice Of The Piney Woods
Lake Livingston, TX
Very rarely hear the med helos on vhf, usually on TxWarn. Only hear them on vhf VMED28 or VFIRE21 when talking to landing zone fire or police units.
Air Medical
Enforcer52
Lake Livingston, TX
Are these listed in Sentinel so I can just add them or do I have to manually program them in?
Should be in the TxWarn listings and should be able to import using Sentinel, but would suggest you invest in ProScan as it is so much more versatile in importing and in organizing your favorite lists. And worth the money in the long run.
Enforcer52
Lake Livingston, TX
Here is a list of the Houston area VHF/UHF freqs for Air Medical but like I said before very rarely hear them on these freqs.
Houston, Texas
Actually I use ARC536, which I am planning on purchasing.
I am more familiar with ARC536 since I have used ARC300 for my Radioshack Pro-164.
Just need to become a premium member so I can import from ARC536
Enforcer52
Lake Livingston, TX
Here is my .hpe file for all my Air and MilAir frequencies for East and Central Texas in case you are interested.
  • Texas Air_MilAir.zip
Enforcer52
Lake Livingston, TX
Although I am in Houston, Texas so I may not be able to pick these up
If you use an outside antenna it should pick up 150-175nm, on my handheld antenna I usually get 75-100nm depending on where I am at. So most everything but the DFW area should be available for you. I am located on Lake Livingston only about 75 miles north of downtown Houston and 55 miles north of IAH, Ground operations is about the only thing I can't receive because too far from airport.
