John_M
poltergeisty said:Which one? :shock: :wink:
Your first post.
Click me.
Click me.
Click me.
Read through tells just about everything.
So it helps?
Yes. If you have an expensive receiver that you want to protect.
Read every one.
Your degree in electrical engineering is from where? Mine's from CUNY. A magnetic shield doesn't have to be grounded - an emf shield does.JMedley_1 said:Al42:
1. The shield does not have to be grounded to stop EMF
Everything with electricity flowing through a non-linear component radiates RF. The question is how much. In the case of a CRT, not enough to matter.2. The original question was for any type of interference.
Do CRT's transmit an RF signal?
Which wouldn't bother a scanner so, since that's what this discussion is about, who cares?3. Power Supply not transmitting Broadband noise. The
purpose of the shield on top of the Powersupply is to stop the power supply from radiating EMF (60hz EMF)
Poorly designed because it was susceptible to magnetic interference.4. Poorly designed? After the design and testing was completed the Bubble Detector detected smaller bubbles with fewer miscues.
You could have gotten a sheet of mu-metal for a few dollars in a few days. Unless you already hasd a CRT shield lying around that you could cut up.5. With any project there are time constraints and so much money available for a project. If the project takes more time than originally projected then you can ask for more money but sometimes it is not always granted. For the shield we used what was available to us.
How long does knowledge take? It took me about 0.1 second to come up with mu-metal.We tried different types of sheet metal for the shield. We used what worked and it worked great. Sure you can find better metals to be used for the shield who's got time for this?
Which had noithing to do with the original thread.6. After a project is completed there are going to be people to criticize. Hindsight is always 20/20. I do not know why you even attempt to critisize when you are absolutely unfamiliar with the project I am describing.
Again - nothing to do with the current thread.7. Call AOR up and tell them how they could have done better with the design of the 8200 and see what they say. The 8200 handheld is under constant developement. (8200MarkII 8200MarkIII)
Oopsies. The shell radiates the signal if the source is inside. It shields what's inside from what's outside only.N_Jay said:What a topic.
Lets take few steps back.
(OK, I know I am going to screw up a few things, so just chime in where you KNOW I am wrong)![]()
RF or EMF radiation (Radio waves) are shielded by conductive material.
If the material makes a complete shell around the object, the interior of that shell is shielded whether or not the shell is grounded. If the shield is not complete it must be grounded to be effective.
Depends. Some shields are to prevent signals from radiating outward. (Like, say, intermediate oscillator products.)This is the type of shielding found in most radios
And incomplete loops around search coils on metal detectors.A unique type of magnetic shielding is the Faraday shield. This is a conductive band placed around a magnetic field source in a particular orientation to intentionally generating an eddy current in the conductive band (converting the magnetic energy into electrical energy). This current then dissipated as heat. You see this shields as copper bands around transformers and metallic tape or mesh loops around CRT monitor tubes.
Al42 said:Your degree in electrical engineering is from where? Mine's from CUNY. A magnetic shield doesn't have to be grounded - an emf shield does.JMedley_1 said:Al42:
All I have to be familiar with is that it's susceptible to interference from a part of itself. That spells poor design regardless of what the project is. Even birdies in scanners are evidence of design that could be improved.JMedley_1 said:Al42 No, your right, it had nothing to do with the original thead. But you did attempt to criticize the project. Again, you are absolutely unfamiliar with the Bubble Detector project.
Since a properly designed power supply doesn't radiate any appreciable emf in the RF range (which is the only thing that would interfere with a scanner), no it couldn't.Radiated EMF from a Power Supply could very well cause problems if close to scanner boards.
The fact that someone thinks that a shield is needed doesn't mean that one is. Plenty of people "fix" things that aren't broken, or fix the wrong thing.Read through Poltergeisty's first post. In case of a CRT
not enough to matter. Tell that to the guy who made up custom steel
side, top, and back panels to protect his receiver.
If it's a magnetic shield there is none. If it's an emf shield it'll radiate the signal if it's not grounded. We're talking about shielding the source, here, remember.To tell you the truth I don't see any need to ground it.
As I said, CUNY. (Back when it was CCNY, but shilelding hasn't changed since Faraday's day.)What school did you go to?
JMedley_1 said:. . . . I am not going to argue with you anymore about the grounding of a shield designed to protect an expensive sensitive receiver from EMF's and noise. Which is what the Topic
was about.
JMedley_1 said:I did bring it up. Because we were talking about interference. Sorry :lol: I also knew that this type of shielding would do nothing for a power supply inside of a radio. A power supply near the outside of the scanner, this type of shielding would provide protection if the power supply is radiating strong EMF.
EM or magnetism? An ungrounded "shield" won't stop EM radiation.JMedley_1 said:Al42: The power supply manufacturer their stupid because they put out a power supply that radiated a little 60hz EMF
Most power supply radiation is due to the diodes or a bad connection, which is in the RF range. 60Hz EM? Probably masked by all the 60 Hz EM floating around from line cords, power lines, etc. The "signal" from the power supply is probably far below the "noise".N_Jay said:Very few power supplies put out enough 60 Hz EMF to bother ANYTHING.
Stands to reason, since there's so much of it in the air. An electronic product sensitive to 60 Hz EM interference would be something like a water soluble fish.Very few products are sensitive to 60 Hz EMF.
JMedley_1 said:The power supply radiated 60hz Emf. Not a magnetic field.
No ground needed to shield. Don't need any formulas.
N_Jay said:JMedley_1 said:The power supply radiated 60hz Emf. Not a magnetic field.
LOL,
Now, explain how you are so sure it was 60 Hz EMF?
If it was not magnetic, then you did not need to use the heavy piece of steel you ended up using.
If it was not magnetic, then you would have had to ground it to get any significant sheilding.
JMedley_1 said:N_Jay said:JMedley_1 said:The power supply radiated 60hz Emf. Not a magnetic field.
LOL,
Read privious post.
JMedley_1 said:Why am I so sure. First of all I witnessed it first hand. Now what would a piece of sheet metal glued on top of the power supply do if the issue was magnetism? Nothing. The power supply radiated 60hz EMF and the piece of sheet matel glued on top stopped it cold. If this post doesn't explain it I don't know what would. The power supply radiated 60hz EMF period.
I'm trying to figure out how a transformer could radiate any EMF more than the wires connected to it. Maybe it's been too long since school, but I'm at a loss.N_Jay said:4) the part you were sheilding was a powersupply transformer. A device, that by its very nature is a source of MAGNETIC fields, and typically not a source of EMF.
