MTA PD is NOT leaving VHF anytime soon, the APX radios are VHF/7-800. I just programmed one for a LT on a new repeater for GCT. There MAY be other versions of the APX and Unity out there depending on the district they are assigned to, and they are also putting in APX mobiles in the RMP's.
MTA PD long range plans are to eventually go 7-800 system wide, but you are talking decades not years, and PD will always want to be able to talk to the trains.
Right now MTA PD is using the OLD Metro21 outfitted to pure P-25 for Staten Island only. A real waste as we could have just installed a VHF base on Chrysler or out there and all would have been fine.
Quote"Happened to come across this in the MTA capital plan program"
Interesting, but as I said they are not leaving VHF only enhancing their coverage with the 7-800 system, that is not built yet in most areas. I understand the build out in NYC taking precedence, and 7-800 won't be available in the GCT until the 7 vendor project is completed, which is now on hold due to an internal investigation that I have no info on. All I can say was the contractor was escorted off the property by PD.
MTA Metro North has NO plans on going NXDN, I just ordered another 1000 HT-1250 portables, and are going to order another 1-200 CDM mobiles. The retrofit radios for the old Mitrek's are Harris M7300 mobiles. The only NXDN radios on property as I have said before is being used by the radio shop on their Wide Area VOIP backed system.
