mic to DB25 on 90 series kenwoods
code3cowboy
CA-CZU
Has anyone connected the mic to the DB25 port on anything? If so, was there anything note worthy?
I want to hook it up this way on a few mobiles to save space.
ramal121
Lots and lots of watts
Calif Whine Country
Yes you can do that. You need to get the mic, ptt ground, etc to the right pins on the DB-25.
Here's the problems;
Are you going to use a X90 mic? How are you going to connect to the weird round connectors. Mates to that are just not out there. You could use a mic with an RJ-45 connector, but they are not as nice as the 90 mics.
You will need to pick an I/O pin as PTT and then program the radio to use that pin as PTT.
90 series radios are not set default for mic audio at the acc connector. A couple of jumpers will have to be moved inside the radio.
Barring that, no problemo.
code3cowboy
CA-CZU
Mahalo, I figured it would be easy, but had to hunt for the Hook option for a pin
The RJ45 mics are the same as the x90 mics, I swap them around all the time (that way I know which radio has the DTMF pad).
