Middletown Fire ground freqencies
chipstew
Middletown, Conn
Searching the database, I am not able to find the fire ground frequencies that Middletown dispatch uses. For a major incident, they refer to "Fire ground 1, 3 or 5" My scanner is programmed for all frequencies listed in Radio Reference, but I do not hear anything after the response switches to one of them.
55engine
Hartford County area
they are on the Middletown trunk I also do believe their main fire dispatch channel is still up VHF last I remember1769818391649.png
nhfdcadet
CETsr
New Hartford, Ct
They're simplex UHF so unless you're close by, you're better off listening over the TRS on 203, 207, or 208.
55engine
I did last night check in the FCC. I did find a cup for UHF, but it was like 2 o'clock in the morning so I will program them in my radio and attempt to go down the Middletown and see if we work in fire for a activated fire alarm comes in, but I had no idea they were using UHF as well. I just only knew about the trunk system and that one VHF channel.
