Midland 13-892 split-second transmit
WB9YBM
What would be the tell tale signs the caps are bad (other than visible damage/leakage)?
If the capacitor developed a short, the radio will either blow fuses or show high current draw (depending on where it's located in the circuit); if it's open or dry, it won't filter (in the case of power supply filter caps), or if taken out and tested with a capacitance meter the value will be out of spec.
