Migrate scan lists from Pro-106 to Pro-668??
tomas21
SoCal
Curious if anyone has found an effective way to migrate scan lists from Pro-106 to Pro-668 playlists.
I have both Win500 & iScan software loaded.
I'm currently doing the following which is manual.
Win500 - Load up Pro-106 scan list (conv view first & then trunked)
iScan - Imported all Freqs from Conv & Trunk), go to Conv tab & Trunked, scroll to right and check box next to each freq cross referencing Win500 tabs and clicking set for each respective freq & playlist for the Pro-668. Then save config to scanner over USB.
Wondering if there is more effective ways out there.
Ronaldski
MI DB Admin
Bay City MI
Ive done it, although I use PSREdit 500.
May-may not work for you, but I just highlight-copy the info in psredit and click in iscan the trunked radio systems tab. Highlight the system you want at the top, then click the talkgroup details tab. Then finally click on the bottom right the clipboard button.
New window will popup and for each column click on it and select what function it is, i.e. talkgroup, alpha tag, etc.
Also in iscan at General settings, select which scanlist# you want the new info to go, that way when you paste the new info in it will be assigned accordingly.
