Minitor 2 PL codes
NRFDTL11Buff
Hey Everyone! Happy Easter! Im not to sure if this is the right thread to put this in but it fits best.
I know that the Motorola Minitor 2's use crystals for the freqs (I have a couple) but can you put PL Codes in em' or just the newer ones (Minitor 3 and up).
Thanks Guys
-Chris
scannersnstuff
to the best of my knowledge there are absolutely no voice pager's that will accept pl/dpl tone's.for the most part you will not really need them.one of the reason's is <and i'm sure there's a couple> when pl is enabled the tone alert monitor you are using will not alway's "trip" accuratly.there are some comm's center's that don't even send the paging tone's out in pl.they use an open carrier for the tone alert portion of the message and/or the message.someone correct me if i'm wrong.
clueless_guy
The only Minitor pagers to ever feature a PL option were the original Minitor I series, and it was a very rare option at that. Nothing from the II to the current V had or has a PL/DPL option. CSQ only. In addition, a Minitor I equipped with a PL board could not decode tones, so there was never a Motorola voice pager that had both PL decode AND tone decode in the same unit.
As far as the tones being transmitted CSQ, the only benefit to doing that is so a receiver with PL/DPL enabled wouldn't have to "hear" the tones. That's fine for voice pagers, which are all CSQ and unaffected by the presence or absence of PL/DPL. The problem comes in with units like portables that have PL/DPL enabled and are functioning as alert receivers. They may not open up even for a correct tone sequence unless the PL/DPL is present. I have personally never come across a system that did not transmit the PL/DPL at the same time as the tones, so I doubt it's very common practice, particularly in FD/EMS ops where portables are often used in lieu of pagers.
Hope this helps.
scannersnstuff
if i'm not mistaken i believe camden county fire communication's nj either used to or still does send their fire/ems tone's out with no pl.i'm not close enough to listen so i can't verify at this time.
