Minitor Minitor 6 Programming Issue
sfd119
Do you have the drivers installed for the programming cradle? Does it show up in the COM port list?
sfd119
It depends on every computer. If you unplug the programming cable does COM5 disappear?
sfd119
Yes, you'll need a driver for it. It needs to communicate somehow. The fact that COM5 doesn't disappear when you unplug tells me it may not be installed correctly. You'll need to download the Minitor 6 PPS...should be something for a driver in the ZIP if I remember right. Install the drivers and it should show up as a COM port.
