Minitor III Programming Cable
Kevin_CCR
Kittitas Co. WA
Hi all,
Recently my fire department surplused some old Motorola and Kenwood radio/pager equipment. Most notably in there was a ton of old Minitor II/III pagers, chargers, a programmer and a Motorola Alert Monitor. Unfortunately the programmer didn't come with a cable, just the dock. Is there a way to convert it to USB or do I need to find the original cable to get the programmer to work?
Thanks,
Kevin
a417
is that the cradle that needs the 3.5 mm stereo plug?
n3obl
Ø
PA
So the M3/m4 cradle its a small 6 pin RJ connector. I don't think its rj45.
That goes to a PIB (Pager interface box). think of it as a rib box for pager.
There is an aftermarket cable on eBay but they want like 50 bucks which connects directly to the cradle.
The original mintior 5 cradles also used the pager interface box. Then at some point motorola redesigned the cradle to put the electronics in the base and use a RJ-45 to 9 pin cable for that model.
wa8pyr
Staff member
Lead Database Admin
Ohio
I got around this issue by taking a Minitor 3/4 programming cradle, adding a 1/8" stereo jack to it and wiring appropriately. Plug the programming cable for my Pro106/PSR500 scanner into it and the computer, and it works like a champ.
I got the idea from another thread here on RR, but I absolutely cannot remember which thread.
ffexpCP
wizard of odd
Michigan
This is exactly what I do. I've just added the stereo jack to my chargers. Much easier to do with amplified chargers. You have to get creative with standard chargers as it doesn't have all the pins.
