MINITOR pager cap codes
W4JLR
Lavonia, GA
I have a MOTOROLA minitor IV and a HT1000 I am very simpley trying to convert a CAP code in the pager to a QCII that I can use in the HT1000, Can some one help me with this?
The CAP code is 110
(It is a 8 second "Solid" tone)
KG4DGN
W4JLR
Lavonia, GA
Does anyone know how to actually turn QCII on in a HT1250, My CPS has it programming correctly but when the tone goes out it still don't work, I read the owners manual it don't say anything about quick Call II
ffexpCP
wizard of odd
Michigan
You probally want to :
*set call alert type to "call alert with voice"
* make sure the call format also matches up right with the tone chart
* be sure to select the right QC-II group under signaling for the desired personality
W4JLR
Lavonia, GA
ffexpCP I assume you are taking about CPS is where I need to check all this rather that in the radio menus itself?
KG4DGN
W4JLR
Lavonia, GA
Followup, I got the HT1250 to "Drop" tones but not recieve, but since my OP i have sold both radio's but I still Own the pager.
Jason
KG4DGN
Dygear
Levittown, NY
Midian has a nice tone signalling chart including QCII tones in chart form that will let you decode the capcode:
http://www.midians.com/pdf/tone_signaling.pdf
I'm a reading this right / It this what I think it is. Are these the wakeup tones that are transmitted after the alert tone? I forget what my dispatcher used to use (Firecom, Nassau County NY.) as their dispatch console. But it had a standard wakeup tone that alternated after the alert tones. Am I able to find this on here, If I can find the make and model of the dispatch console?
DFD140
Dyersburg, TN
Years ago when I used to dispatch the local FD I entered a code of 100 into an old zetron encoder. This produced a low 8 second solid tone, which they still use today. Can anyone tell me what that translates to in Hz? It will set off a Minitor V.
W4JLR
Lavonia, GA
DFD140 If you will send me an PM with your email address I will email you a tone converter program it probably will be 330.9Hz
