Mixed Mode Scanning Troubles
firemedic834
Hello all!
NX5200 and NX5700 radios with select channels set to mix-mode - receive analog and conventional and transmit in P25.
When the mix-mode channel is the selected priority channel and scan feature is turned-on. The radio does not hear the conventional radio traffic. Turn the scan feature off and radio hears the conventional radio traffic.
The selected channel is in the scan list.
Any help on a solution?
kd4efm
EL98 Florida
:unsure:
Why mixed mode? I understand save on channels used, but why not 1 extra channel for the analog, and 1 for the p25.
Just thinking out loud, that would make more sense. unless it's a work radio and deals with paging etc.
firemedic834
:unsure:
Just thinking out loud, that would make more sense. unless it's a work radio and deals with paging etc.I
It is a public safety radio. The mixed-mode is to capture the analog page tones and voice for the initial dispatch.
The radio acts like it isn’t scanning the conventional side of the channel/frequency.
kd4efm
EL98 Florida
I would separate the two then. This can cause more headache than needed.
My 2 cent suggestion
firemedic834
Fair enough. The odd thing... There is another personality from the same system in the same zone programmed as mixed mode. It works as designed. I have checked the configuration of between the two personalities. No differences. :unsure:
