MMDVM Mixed P25 Mode
apx7000xe
GA/SC State Line
I am currently trying to help another ham swap his machine from FM only to FM/P25 mixed mode where if you key up in P25, it repeats P25 or if you key up in analog, it repeats analog similar to the way the MMDVM already does for various digital modes. Repeater is a early generation DR-1X. Using a Repeater Builder MMDVM Pi Hat board and the newest version of Pi Star. When enabling FM and P25 together, P25 lights up red. When I turn off FM, P25 comes back up. I have tried this on every digital mode and FM causes them all to light up red. I will attach startup logs below. Is it even possible to run it in this configuration? If so what am I doing wrong?
Code:
Starting logging, please wait...
I: 2021-10-22 02:39:30.529 This software is for use on amateur radio networks only,
I: 2021-10-22 02:39:30.530 it is to be used for educational purposes only. Its use on
I: 2021-10-22 02:39:30.530 commercial networks is strictly prohibited.
I: 2021-10-22 02:39:30.530 Copyright(C) 2015-2020 by Jonathan Naylor, G4KLX and others
M: 2021-10-22 02:39:30.530 MMDVMHost-20210617_PS4 is starting
M: 2021-10-22 02:39:30.530 Built 16:32:57 Jun 17 2021 (GitID #9106fd6)
I: 2021-10-22 02:39:30.530 General Parameters
I: 2021-10-22 02:39:30.530 Callsign: N4TS
I: 2021-10-22 02:39:30.530 Id: 1234567
I: 2021-10-22 02:39:30.530 Duplex: yes
I: 2021-10-22 02:39:30.530 Timeout: 240s
I: 2021-10-22 02:39:30.530 D-Star: disabled
I: 2021-10-22 02:39:30.530 DMR: disabled
I: 2021-10-22 02:39:30.530 YSF: disabled
I: 2021-10-22 02:39:30.530 P25: enabled
I: 2021-10-22 02:39:30.530 NXDN: disabled
I: 2021-10-22 02:39:30.530 POCSAG: disabled
I: 2021-10-22 02:39:30.530 FM: enabled
I: 2021-10-22 02:39:30.530 Modem Parameters
I: 2021-10-22 02:39:30.530 Port: /dev/ttyAMA0
I: 2021-10-22 02:39:30.530 Protocol: uart
I: 2021-10-22 02:39:30.530 RX Invert: no
I: 2021-10-22 02:39:30.530 TX Invert: yes
I: 2021-10-22 02:39:30.530 PTT Invert: no
I: 2021-10-22 02:39:30.530 TX Delay: 100ms
I: 2021-10-22 02:39:30.530 RX Offset: 0Hz
I: 2021-10-22 02:39:30.530 TX Offset: 0Hz
I: 2021-10-22 02:39:30.530 RX DC Offset: 0
I: 2021-10-22 02:39:30.530 TX DC Offset: 0
I: 2021-10-22 02:39:30.530 RF Level: 100.0%
I: 2021-10-22 02:39:30.530 DMR Delay: 0 (0.0ms)
I: 2021-10-22 02:39:30.530 RX Level: 50.0%
I: 2021-10-22 02:39:30.530 CW Id TX Level: 50.0%
I: 2021-10-22 02:39:30.530 D-Star TX Level: 50.0%
I: 2021-10-22 02:39:30.530 DMR TX Level: 50.0%
I: 2021-10-22 02:39:30.530 YSF TX Level: 50.0%
I: 2021-10-22 02:39:30.530 P25 TX Level: 50.0%
I: 2021-10-22 02:39:30.530 NXDN TX Level: 50.0%
I: 2021-10-22 02:39:30.530 POCSAG TX Level: 50.0%
I: 2021-10-22 02:39:30.530 FM TX Level: 50.0%
I: 2021-10-22 02:39:30.530 TX Frequency: 147120000Hz (147120000Hz)
I: 2021-10-22 02:39:30.530 Use COS as Lockout: no
I: 2021-10-22 02:39:30.530 FM Parameters
I: 2021-10-22 02:39:30.530 Callsign: N4TS/R
I: 2021-10-22 02:39:30.530 Callsign Speed: 20WPM
I: 2021-10-22 02:39:30.530 Callsign Frequency: 1000Hz
I: 2021-10-22 02:39:30.530 Callsign Time: 10mins
I: 2021-10-22 02:39:30.530 Callsign Holdoff: 1/0
I: 2021-10-22 02:39:30.530 Callsign High Level: 50.0%
I: 2021-10-22 02:39:30.530 Callsign Low Level: 20.0%
I: 2021-10-22 02:39:30.530 Callsign At Start: yes
I: 2021-10-22 02:39:30.530 Callsign At End: yes
I: 2021-10-22 02:39:30.530 Callsign At Latch: no
I: 2021-10-22 02:39:30.530 RF Ack: K
I: 2021-10-22 02:39:30.530 Ack Speed: 20WPM
I: 2021-10-22 02:39:30.530 Ack Frequency: 1750Hz
I: 2021-10-22 02:39:30.530 Ack Min Time: 4s
I: 2021-10-22 02:39:30.531 Ack Delay: 1000ms
I: 2021-10-22 02:39:30.531 Ack Level: 50.0%
I: 2021-10-22 02:39:30.531 Timeout: 180s
I: 2021-10-22 02:39:30.531 Timeout Level: 80.0%
I: 2021-10-22 02:39:30.531 CTCSS Frequency: 67.0Hz
I: 2021-10-22 02:39:30.531 CTCSS High Threshold: 30
I: 2021-10-22 02:39:30.531 CTCSS Low Threshold: 20
I: 2021-10-22 02:39:30.531 CTCSS Level: 20.0%
I: 2021-10-22 02:39:30.531 Kerchunk Time: 0s
I: 2021-10-22 02:39:30.531 Hang Time: 7s
I: 2021-10-22 02:39:30.531 Access Mode: 1
I: 2021-10-22 02:39:30.531 COS Invert: no
I: 2021-10-22 02:39:30.531 RF Audio Boost: x1
I: 2021-10-22 02:39:30.531 Max. Deviation Level: 90.0%
M: 2021-10-22 02:39:30.531 Opening the MMDVM
I: 2021-10-22 02:39:32.541 MMDVM protocol version: 1, description: MMDVM 20190130 (D-Star/DMR/System Fusion/P25/NXDN/POCSAG) 12.0000 MHz GitID #ff7a9fd
E: 2021-10-22 02:39:32.572 Received a NAK to the SET_FM_PARAMS1 command from the modem
I: 2021-10-22 02:41:02.875 This software is for use on amateur radio networks only,
I: 2021-10-22 02:41:02.875 it is to be used for educational purposes only. Its use on
I: 2021-10-22 02:41:02.875 commercial networks is strictly prohibited.
I: 2021-10-22 02:41:02.875 Copyright(C) 2015-2020 by Jonathan Naylor, G4KLX and others
M: 2021-10-22 02:41:02.875 MMDVMHost-20210617_PS4 is starting
M: 2021-10-22 02:41:02.875 Built 16:32:57 Jun 17 2021 (GitID #9106fd6)
I: 2021-10-22 02:41:02.875 General Parameters
I: 2021-10-22 02:41:02.875 Callsign: N4TS
I: 2021-10-22 02:41:02.875 Id: 1234567
I: 2021-10-22 02:41:02.875 Duplex: yes
I: 2021-10-22 02:41:02.875 Timeout: 240s
I: 2021-10-22 02:41:02.875 D-Star: disabled
I: 2021-10-22 02:41:02.875 DMR: disabled
I: 2021-10-22 02:41:02.875 YSF: disabled
I: 2021-10-22 02:41:02.875 P25: enabled
I: 2021-10-22 02:41:02.875 NXDN: disabled
I: 2021-10-22 02:41:02.875 POCSAG: disabled
I: 2021-10-22 02:41:02.875 FM: enabled
I: 2021-10-22 02:41:02.875 Modem Parameters
I: 2021-10-22 02:41:02.875 Port: /dev/ttyAMA0
I: 2021-10-22 02:41:02.875 Protocol: uart
I: 2021-10-22 02:41:02.875 RX Invert: no
I: 2021-10-22 02:41:02.875 TX Invert: yes
I: 2021-10-22 02:41:02.875 PTT Invert: no
I: 2021-10-22 02:41:02.875 TX Delay: 100ms
I: 2021-10-22 02:41:02.875 RX Offset: 0Hz
I: 2021-10-22 02:41:02.875 TX Offset: 0Hz
I: 2021-10-22 02:41:02.875 RX DC Offset: 0
I: 2021-10-22 02:41:02.875 TX DC Offset: 0
I: 2021-10-22 02:41:02.875 RF Level: 100.0%
I: 2021-10-22 02:41:02.875 DMR Delay: 0 (0.0ms)
I: 2021-10-22 02:41:02.875 RX Level: 50.0%
I: 2021-10-22 02:41:02.875 CW Id TX Level: 50.0%
I: 2021-10-22 02:41:02.875 D-Star TX Level: 50.0%
I: 2021-10-22 02:41:02.875 DMR TX Level: 50.0%
I: 2021-10-22 02:41:02.875 YSF TX Level: 50.0%
I: 2021-10-22 02:41:02.875 P25 TX Level: 50.0%
I: 2021-10-22 02:41:02.875 NXDN TX Level: 50.0%
I: 2021-10-22 02:41:02.875 POCSAG TX Level: 50.0%
I: 2021-10-22 02:41:02.875 FM TX Level: 50.0%
I: 2021-10-22 02:41:02.876 TX Frequency: 147120000Hz (147120000Hz)
I: 2021-10-22 02:41:02.876 Use COS as Lockout: no
I: 2021-10-22 02:41:02.876 FM Parameters
I: 2021-10-22 02:41:02.876 Callsign: N4TS/R
I: 2021-10-22 02:41:02.876 Callsign Speed: 20WPM
I: 2021-10-22 02:41:02.876 Callsign Frequency: 1000Hz
I: 2021-10-22 02:41:02.876 Callsign Time: 10mins
I: 2021-10-22 02:41:02.876 Callsign Holdoff: 1/0
I: 2021-10-22 02:41:02.876 Callsign High Level: 50.0%
I: 2021-10-22 02:41:02.876 Callsign Low Level: 20.0%
I: 2021-10-22 02:41:02.876 Callsign At Start: yes
I: 2021-10-22 02:41:02.876 Callsign At End: yes
I: 2021-10-22 02:41:02.876 Callsign At Latch: no
I: 2021-10-22 02:41:02.876 RF Ack: K
I: 2021-10-22 02:41:02.876 Ack Speed: 20WPM
I: 2021-10-22 02:41:02.876 Ack Frequency: 1750Hz
I: 2021-10-22 02:41:02.876 Ack Min Time: 4s
I: 2021-10-22 02:41:02.876 Ack Delay: 1000ms
I: 2021-10-22 02:41:02.876 Ack Level: 50.0%
I: 2021-10-22 02:41:02.876 Timeout: 180s
I: 2021-10-22 02:41:02.876 Timeout Level: 80.0%
I: 2021-10-22 02:41:02.876 CTCSS Frequency: 67.0Hz
I: 2021-10-22 02:41:02.876 CTCSS High Threshold: 30
I: 2021-10-22 02:41:02.876 CTCSS Low Threshold: 20
I: 2021-10-22 02:41:02.876 CTCSS Level: 20.0%
I: 2021-10-22 02:41:02.876 Kerchunk Time: 0s
I: 2021-10-22 02:41:02.876 Hang Time: 7s
I: 2021-10-22 02:41:02.876 Access Mode: 1
I: 2021-10-22 02:41:02.876 COS Invert: no
I: 2021-10-22 02:41:02.876 RF Audio Boost: x1
I: 2021-10-22 02:41:02.876 Max. Deviation Level: 90.0%
M: 2021-10-22 02:41:02.876 Opening the MMDVM
I: 2021-10-22 02:41:04.887 MMDVM protocol version: 1, description: MMDVM 20190130 (D-Star/DMR/System Fusion/P25/NXDN/POCSAG) 12.0000 MHz GitID #ff7a9fd
E: 2021-10-22 02:41:04.918 Received a NAK to the SET_FM_PARAMS1 command from the modem
Download the log: here
Pi-Star web config, © Andy Taylor (MW0MWZ) 2014-2021.
Need help? Click here for the Support Group
Get your copy of Pi-Star from here.
