Mobile Antenna Mounting Location
Chris155
Southern Maryland
Hello and thanks in advance. On the pictured truck I have an nmo mount Larsen whip & coil tuned for 11m center of the roof on the aluminum cap, it works great. I’m looking to add a ladder rack for carrying 2 aluminum canoes so I’ll need to mount a suitable cb antenna somewhere else. This is an interstate to forest service road truck.
I’ll drill a hole most anywhere but the windshield. I’m thinking 1/4 wave whip or 7’ top load skip shooter mounted about eye level near the corner of the cap. Looking forward to any ideas or suggestions.
WSAC829
Wisconsin Radio 225
EN64ak
Since you already have an NMO mounted Larsen whip, just get an NMO hood/fender mount and use the same antenna. Quick and easy. I use hood/fender mounts for both CB and VHF/UHF with good results.
slowmover
Fort Worth
Canoes to be side-by-side and extending past windshield header?
@WSAC829 solution “works”, but not ideal, obviously, for xtra-long range given tall bed cap and now more metal above cab.
How far ahead of cab to mitigate interference is the question.
Ball-mount on bed exterior is another possibility; again, not ideal (“Ideal” being roof center).
See BREEDLOVE site for more ideas.
Chris155
Southern Maryland
Fender mount may work, we can probably trail run that with components I have on hand. The canoes are 16’ & 17’ so they’ll definitely hang out above the hood partially. A ball mount and 6’ plus antenna in the area of either pink x in this picture would get the maximum metal under the antenna and max height above metal. My concern is too much metal along side the antenna. The fender mount would definitely keep the Larsen coil clear of metal to the sides.
