Mobile GMRS NMO mount duel band antenna
wildland23
Eatonville, Wa.
I have a B-Tech model 50V2 GMRS radio mounted in my F-150 pick-up. Looking for a NMO mount, gain type, duel band, antenna with spring for GMRS repeater use as well as monitoring VHF high band (150-170) public safety frequencies.
prcguy
kny2xb
North Clearwater, FL
No gain on that one, it’s a 1/4 wave equivalent or less on all bands.
I was going by the factory specs which state Gain (dBi) VHF/UHF/700-800 Unity / 5 dBi / 4 dB respectively
I've had good luck with mine so far, although I've only used it on GMRS, I haven't tested it on MURS or as a scanner antenna yet
That one does not have a spring, but you can add one:
If you want Chrome:
Or Black:
I've used the EM Wave mentioned above, along with the Larsen NMO-150/450/758SF and I've been happy with them. Not "gain" antennas, but they've worked fine for me. Sometimes lower gain is beneficial if you are in the mountains.
prcguy
Go here and check out the antenna range test I did which includes the EM-M43002. Best performance is no better than a 1/4 wave whip on VHF/ UHF as most of the triband antennas perform.
hill
Middle River, MD
Would use the EM Wave antenna and not worry about gain, since the ham/Amazon antennas most likely have inflated gain figures.
EM Wave is commercial antenna company used in public safety.
This antenna would outlast this vehicle and many more to come. Also the other one is way to tall and think it could use a PL259 connection and these really aren't made for antennas like a NMO..
