I have an email into park management about what I can and can't get away with. That will affect how high I can go. I suppose with a wooden frame, I can get a steel sheet flat. Just a regular 1 x 3x3 or 5 x 4x4 steel sheet. Is bigger better?
You'd want 1/4 wavelength on your lowest operating frequency radiating out away from the antenna base.
So, for VHF, you'd essentially want a piece 36" in diameter under the antenna base. Or, you can just do 3 radials 18" long under the antenna. Can be any conductive material.
But, I think you should wait until you hear back from the park management about what is allowed. There are many ways to achieve this depending on what they'll permit, what your budget is, what your skill level is. If they will let you put up a base antenna on a pole next to the trailer, that will work well. If they don't, then you need to keep it low profile.
There are solutions, just depends….
Sorry, I should have been more clear. My home runs north-south. The north end is the one with the berm about 100 feet away and the south end it right up against the trees and berm behind us. Would it better to put it on the north end of the mobile or the south end? Please see graphic. Where the tree lines start is where the berms start.
It's not likely going to make a difference. VHF/UHF/700/800MHz stuff that you might want to listen to is mostly line of sight, so lots of dirt between you and the transmitter is going to be a problem. The only way around(over) that is to get your antenna above it. There may be some line of sight improvements depending on exactly where the local transmitters are, and you'd need to figure that out.
I'm still waiting to hear back from Park management on what I can do, but I am seeing a trend towards higher is better. Please remember. I'm still learning, and I'm not ready for my technician yet, and anything antenna is a major learning problem for me yet. I'm in favor of a small frame that would hold something. I'm not planning on getting into HF for a while at least, so really tall towers are out.
Avix.
I get it. Like I said, line of sight is your friend.
But do remember this is a hobby, so we do the best we can with the limitations and budget we have. The park management people will be the ones you have to abide with, so figuring that out will be your challenge.
