- Joined
- May 11, 2021
- Messages
- 7
Hello! First time poster here. thought I'd seek advice for this issue I am troubleshooting. I am in the process of tuning a CB antenna to my car and I'm looking for any advice.
Vehicle: 2015 Honda Civic
Mounting Location: Center Trunk (Drilled 1/2'' hole)
Mount: Firestik K-154A Cowl
Coax: RG-8X 18'
Antenna: Wilson Silver Load FGT 3' Fiberglass
(Also tried Firestik Firefly 3' Fiberglass)
Radio: President Thomas
The issue is that the SWR is about 1.3 when the trunk is open, but 2.3+ when it's closed. I guess this is a ground plane issue?
I confirmed the trunk latch is not the problem, I completely removed the trunk latch, closed the trunk and still had 2.3+ SWR. I also completely disconnected the car battery to check if there was something electronic causing the issue. I tried pushing against the antenna with a spring installed while the was trunk closed to see if the angle was an issue, but it made no noticable difference.
I went inside the trunk and closed it to see if there is any kinks in the coax or anything obvious; not as far as I could tell. I do have two ground straps installed on each trunk hinge to the vehicle chassis, and confirmed good continuity. I also confirmed no continuity between the mount and center pin.
Note: I am using a NanoVNA to check the SWR, I find it a lot easier because I don't have to transmit every time to check. I do have a generic SWR meter and it is about the same readings. Some of the pictures I attached are in my garage but I am tuning in a wide open area.
So my question is, is there anything I can do to help the SWR when the trunk is closed without having to install a tuner? I find it strange that I get a good reading when it's open. The trunk is sitting on the rubber gasket when it's closed, only the trunk hinge has continuity with the rest of the car. I have a spring, but for now it is off because the SWR appears to be lower without the spring. Thanks for any advice.
Coax: RG-8X 18'
