Mobiletech NXDN TRS
ak716
'Merica
Riveting stuff here...
Mobiletech Site 31 (Attica) is reporting a new neighbor of R13-135 CC 42842 153.5525. A good old-fashioned FCC license search shows three active licenses to Mobiletech, all within the area. Site 31 should probably be a neighbor, too....so.... if anyone wants to go hunting and can receive Site 31 and is close to it or east of it, have at it.
WRPT841
WQYK725
WQQB319
If it is anything to anyone, I can "see" the activity on the spectrum, but it is too weak to decode, and I'm west from Attica. It's not showing up as a neighbor for Site 6, 67, but is for Site 72 (as do 14f other ones, some near all three license locations)
k2hz
Rochester, NY
WRPT841
WQYK725
WQQB319
I suspect it is WRPT841 Nunda new site known to be pending. The other call signs are exiting sites. Nunda would be a neighbor to 72 Centerville and 31 Attica.
I have a weak signal here and believe Nunda should be stronger but I will be attempting to confirm the site.
k2hz
Rochester, NY
I just looked at the license and the site is not where I expected and the ground elevation isn't that great so the signal strength I am hearing is consistent with the Nunda location. Not getting good decode right now but I will watch it tomorrow and probably get enough to submit it.
It is a neighbor to Site 42, Dansville and the just relocated Site 60, Geneseo so that confirms Nunda.
Thanks for the heads up!
R0am3r
Salt Water Conch
Oneida County, NY
The Fulton (R13-25) and Savannah (R13-30) sites also show a new neighbor, 150.9575 (R13-138). The Niles and Pulaski NLs doesn't include 138.
The Tully site (R13-12) is MIA this morning. The usual neighbor sites are not listing it.
k2hz
Rochester, NY
It is probably WRAC753 but license lists both Oswego and Wolcott sites. I am checking on it but it is very weak now. It is also on Webster and Williamson NLs. Most likely it is Wolcott since there is an existing Oswego site and it would probably be on Pulaski NL.
I am also checking on Site 12. They got a license a few years ago for a site near Homer that could be a replacement.
There are a lot of new schools TGIDs I have not been able to identify. The RID #s are now over 4000 so they added a lot of subscribers in the last year,
k2hz
Rochester, NY
Added Sites 135 and 139 to RRDB but both are too weak to get any decode other than to confirm RAN. Also 153.5525 has heavy local Site 26 voice channel activity.
I am seeing a new TG 265 in the Wolcott area which could be Red Creek CSD and TG 267 in the Nunda area that could be Keshequa CSD. Not able to get any voice reception to confirm yet.
I was advised that Site 12 should be active but it was gone from Neighbor Lists and no CC heard. I see it is back active now.
R0am3r
Salt Water Conch
Oneida County, NY
Tully (Site 12) is indeed back on the NL list(s) and I see the CC channel on 153.5450.
mciupa
Canadian DB Admin
Moderator
I'm here a lot
Up here in Toronto tonight I am receiving Attica on DSDPlus FastLane. It is coming through as NEXEDGE96 as opposed to 48
mciupa
Canadian DB Admin
Moderator
I'm here a lot
Likely. I was surprised to pick up a system site from 130+ miles away!
