BOBRR
Hello,
For the NOAA weather broadcasts on, e.g., 162.5 MHz:
What is the correct mode ?
fm, or...?
Thanks,
R.
fm, or...?
Thanks,
R.
fm, or...?
from,
- The FCC private land mobile radio narrowbanding rule does not affect the NOAA weather channels.
Narrowbanding - The RadioReference Wiki
wiki.radioreference.com
It is "narrow-band" FM. In other words, if your radio also supports broadcast band FM, that would be the wrong mode. Pretty much the same as you would use for non-digital police and fire stuff.
Wait, only broadcast band uses FM, and commercial two way radios only use Narrow FM? Is this what you are saying @MStep ?
And VHF Marine uses 16K0F3E bandwidth/emission. It’s exempt from the narrow banding mandate as is Weather radio transmitters, everything below 50 MHz, some MURS channels, 470-512 MHz, and GMRS and of course Ham radio.
Some of those Google results pull up web pages with lots of disinformation on them.
Just for fun, I set the scanner to pick up NOAA in the AM mode. Sounded ok that way too. Perhaps the following scenario is no longer worth it thanks to the ability to look on your mobile device for weather. However, with traditional FM broadcast band isn't as popular given one can find music elsewhere, why not use some of those unused FM frequencies (due to stations that are defunct) rebroadcast NOAA Weather radio?
I know there are many factors here but I'm just being abstract and/or thinking from an earlier time.
