XTL/XTS5000 Model Number issues
TomWinkel
Hello, I have an XTS 5000, the current codeplug says the model number is for a model 3 (H18UCF9PW7AN), the codeplug I've written says the model number should be for model 2 (H18UCF9PW6AN)...I get an error message that model doesnt match, and it won't write thee new plug, any idea how to fix this.......thanks in advance
TomWinkel
you are going to have to read the model III radio to get its codeplug, open the model II codeplug in a seperate instance of CPS and do a top node drag and drop from the model 3 to the model 2. Then correct any errors that get caused in the conversion.
unfortunately, I bout it from a third party, and don't have access to the other radio
mikegilbert
MHz so good
Los Angeles
  1. Open two instances of CPS
  2. Read your current model 3 radio in the first instance
  3. Open the model 2 codeplug in the second instance
  4. Perform a top level drag and drop from the top of the tree in one window to the other window
  5. If needed, resolve any invalid fields
  6. Write the codeplug
  7. Enjoy your radio!
