Teambudjr
Going on some long trips and I would like to know if the accessory (lighter plug) will handle the power needed to operate a CB or even a 2mm ham radio ??? Not looking for a permanent installation. Thanks
it will entirely depend on the current load of the radio you use. What units are you thinking of?Going on some long trips and I would like to know if the accessory (lighter plug) will handle the power needed to operate a CB or even a 2mm ham radio ??? Not looking for a permanent installation. Thanks
— I suggest you look over the section on Vehicle Wiring.
The owners manual states that the outlets have a 20amp rating. You may not be able to run max power on your radio, but you should be fine. Yes, that's undoubtedly the rating of the fuse, but you cannot tell me that a major automobile manufacturer would use wiring good for 5 amps and put a 20 amp fuse on the circuit. In spite of what some believe, companies like GM generally try to *avoid* lawsuits and vehicle recalls.
Totally up to you, but I'd believe the manufacturer's publication over random folks on the Internet.
Would a permanent installation be better? Oh sure. But don't let anyone tell you what you are looking to do isn't a viable option.
Wow.
I think your intentions are honorable, but your replies are very difficult to understand.
I think you are overlooking one critical item here. The OP specifically said " Not looking for a permanent installation ". He just wants to go on a trip and throw a CB and ham rig for his trip then remove it. You went quite above and beyond what he was looking for.
It's really simple. Throw in the CB and the ham rig, keep the power to 20 watts or less and enjoy the road trip.
No more cigarette/cigar lighters any more. (Smoking is so passé ). They're called power outlets now. They're meant to power a range of external devices rather than supply current to a simple heating element. Best bet is to check your owner's manual and see what fuse is used to protect the outlet.
For example, my Jeep has three outlets. (One on the dash, one inside the center console and one in the back near the rear hatch). They each have their own 20 Amp fuse. So, in my case, a 50 - 60 Watt mobile radio would work with no problems while plugged in to one of the power outlets.
That said.. I have an Icom IC-7000 mounted in the Jeep. The specs say that it draws up to 22 Amps. Because of this, I have it hooked directly to the battery.
