Modify display variables
N8LHG
Ok folks, hit me with your knowledge. Since the battery voltage variable is useless on the sds200, I ran across this picture and want to know how this guy changed his voltage variable into a noise number... I must have this! 😄
RandyKuff
Lorain, Ohio
Open Sentinel and open Edit Display ... Select the block in the left window... Use the pulldown at the top of the right window and select Noise...
RandyKuff
Lorain, Ohio
You can backup your display settings... Play to your hearts content... If you hose it big time just import the backup to it...
Look under the File Tab...
