Molex housing help-KAP2
atcsdeland
Deland, FL
does anyone know the correct Molex part numbers for the 6 position pin and socket housings used in the Kenwood KAP-2 kit. I've been able to find the correct pins and sockets but am striking out on the housings. Any help would be greatly appreciated. Thank you-
Travis
atcsdeland
Deland, FL
E59-0419-05SQUARE PLUG
1.95​
E23-1257-05CRIMP TERMINAL
1.49​
I can order those or you can order from www.kenwoodparts.com
I have the KAP-2 kits but want the plug and socket housings so that I can make some modular extension cables. That is why I wanted both pin and socket housings-trying to put together something that avoids cutting the wires on the KAP-2 lead. Evans, didn't you used to work for a guy down in the Lakeland area? We met back when Dave and I worked with you guys on the ATCS receive site. If I don't have any luck on the housings I'll get back to you on the plug housings. Thank you for the reply.
kd4efm
EL98 Florida
Yes, I'm still here in Lakeland.
kd4efm
EL98 Florida
by the way, the cable with the end
E37-1113-25CABLE (6 PIN) CONNECTOR
20.12​
atcsdeland
Deland, FL
As a follow-up to this thread-for those who are interested, here are some part numbers for the housings. I found them at Digikey
for around $0.35ea. I don't have numbers for the actual pins and sockets as I had plenty:
receptacle housing:
Molex # 03-06-1062
Digikey # 23-0003061062-ND
plug housing:
Molex # 03-06-2061
Digikey # WM1225-ND
