77monarch77
Hi all,
I've been a scannist for years but, due to a disability, have just started to get serious about it. I recently picked up a "good" scanner... a Pro-95. It works well and the trunking feature is great. I've pretty much got the EDACS system figured out. The Motorola system... well... that's another story for another time. Since, like I said, I've gotten serious about the hobby, I was looking for a good base antenna. An elderly gentleman that just recently passed away had a Monitenna that his son removed from the roof of his house. All of this guy's gear was practically given away (naturally, I found out too late) and the antenna was all that remained. I acquired it for $10. It's in excellent condition.
Anyway, I have a few questions about mounting this antenna. First, the antenna is attached, fastened to, or integrally a part of an arm (of sorts). Looking at it, one end is the antenna end and the other is the mounting end. My intention is to mount this on a standard (stock) RS 1 1/4 mast. In doing so, won't the antenna end sag after a time? If it won't sag on it's own, it will sure get some help this winter with the addition of snow weight. [I live in Central New York State]. Would it be a good idea to add a gusset or brace (between the arm and the mast) to offset the weight differential caused by the snow load or time sag?
Second, I know that this is an omni-directional antenna, but in a strange sort of way it kind of looks like a "misfit" yagi. In other words, it looks like it may perform better if it was pointed (aimed) in the general direction of the tower facility which uses the frequencies that I monitor most often. Is this true or did my overactive mind just conjure up this "theory"? If it is true, and as far as aiming goes, which end should be pointed towards the transmitter? Height won't be a factor as I should be about 20ft. above my roofline when it's installed. Yes... it'll be very securely mounted and sufficiently guyed as well!
One more question... I was thinking of having a dedicated 800Mhz antenna just for trunking purposes. I was also thinking of making my own. I'd like to take a mag-mount mobile cell antenna apart and use the whip and it's own mount and attach it opposite the Monitenna. To the best of my knowledge, and since I'll have lost the ground plane (vehicle), I'll have to devise another one. What do I need to do? I'm assuming that I'll need a steel or aluminum plate to attach the whip to, an insulator of some type between the whip and plate, and then add some radials. How long do the radials have to be? How many are necessary? Is there a formula for these calculations? Am I wasting my time? I always put a dollar figure on everything I do. If I end up with a million hours in this project it would be cheaper in the long run just to purchase exactly what I need and be done with it!
Well... that's quite a lot of words for a newbie!!! I hope that I didn't overstep my bounds for a first post. I'd certainly appreciate any and all help, suggestions, or opinions.
Thanks for your time,
Monarch
Monarch
