Update! I was successfully able to use the MOSWIN file downloaded from RR with a couple of modifications.
1st Download the site list from RR
2nd Open the file in Excel
3rd Remove the 1st column titled "Sysid"
4th Line 73, Memphis Site has another site entered in where the frequencies should be. Remove the 1CE, Then Copy and past the remaining data on that line and paste at the end of the sheet. (below site "TRS").
5th Go back and delete the information that was just pasted from line 73.
6th Resave the CSV and now you can import in to the Unication PPS.
I hope this helps others having issues importing.
