Moto MT2000 Programming
ob123
NJ
ATF1224 said:
That's also not necessarily true either. I use a Dell Latitude CPi PII with Windows 98 to program radios, but I use the "Restart in MS-DOS" mode on the shut down screen to enter pure DOS. Running the RSS in a DOS box under Windows will not work and you could brick the radio. A PII is about the fastest I would use for an RSS work, though. Most RSS packages of later versions are pentium-compatible now. Try finding MTSX Version 06.07.00, which is what the vast majority of MT2000's i've seen are programmed with.
Ok, that is what I do I have Windows 98, I restart it in MS-dos mode, find the mrss disk and open the dir file to the program.... once I am in the dir, I just type in the runtime address and it boots up....So far I have only programed mt2000 on windows 98 in ms-dos mode, that should be your best bet....
ob123
NJ
Matt_45 said:
I am using a start-up disk to get into DOS. I'll check into my processor on the unit. It's so odd...i was able to read the radio just fine. It's writing back that's been proven difficult.
Even if you have the start up disk for dos, the computer is to fast....You probally need windows 98 or lower.... If you do corrupt your codeplug, it may still be recoverable if you have the arcive file saved....
